Tools & Hardware - Others Logo
D
DEBORAH COCHRAN Posted on Feb 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My brand new Bostitch impulse 30 stapler arrived and the spring is not attached. Is there a diagram i can use to re attatch it.
Chris Walker
Level 3:
Top Expert:
  • Master 1,573 Answers
  • Posted on Mar 15, 2019
Chris Walker
Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1244349
Points
21965
5 Related Answers
Chuck Nelson
  • 24 Answers
  • Posted on Apr 14, 2009
SOURCE: wanted to unplug my plunger to my s32 sx bostitch
The spring is located under the head valve.Turn the head upside down put in the spring and than the head valve
Anonymous
  • Posted on Jun 04, 2009
SOURCE: looking for the bostitch m111fs flooring stapler instructions
Go to the Bostitch / Stanley website http//www.cpobostitch.com/ Browse for the product as if you are shopping ot buy it. Under the Specifications tab you can download a Schematic and/or Owners Manual in .pdf format. Quick Link to Bostitch MIIIFS owners manual: http://www.cpobostitch.com/static/manual/miiifs.pdf
Anonymous
  • Posted on Apr 26, 2010
SOURCE: door springs, part no. H286, for a Bostitch H2B stapler
Parts for the Bostitch H2B Hammer Stapler can be purchase from MJS Floorcoverings Manfield Brisbane
Anonymous
  • Posted on Dec 10, 2011
SOURCE: There is a Stanley bostitch model B2000 stapler in
The person that asked this is probably long gone, but in case anyone else comes across this... I had the exact same problem when I dropped this same stapler today and the spring came out. After examining it for a bit, I realized where the spring had to go and fixed it.
Open the stapler the same way you would as if you were replacing the staples and look at the top piece, towards the back. There will be an elongated black hook here to attach one end of the spring. The trick is where you route the spring after that... look towards the front end of the same top piece, and you'll see 2 holes in the metal. You need to push the spring up through the first hole, then pull it back down through the second hole (you may want to use a straightened paper clip to snag the spring so you can pull it through that second one), and only then do you attach the other end of the spring to the hook in the sliding metal piece that advances the staples in the staple holder.
And that's it!
puertobori
  • 7733 Answers
  • Posted on Apr 12, 2012
SOURCE: How do I put the Bostitch B660 stapler back together?
MAYBE THIS IS USEFUL http://www.ereplacementparts.com/bostitch-21680b-industrial-fine-wire-stapler-parts-c-29443_29444_29449.html
1helpful
2answers
Bostitch electric stapler wont open
Ungplug the stapler. In the area that you insert the paper, although its narrow, above where the paper is inserted you will see a metal straight/flat bar. Use a tool such as a letter opener and push the bar upwards. You should not have to push too hard. When you hear a click, you should be able to open the stapler. Remove the jammed staples. Plug in stapler and it should be work. (note: This is the how I fixed the Bostitch impulse stapler, but I was following instructions to fix another type of electric stapler and this worked)
4answers
Spring to stapler fell out
Hello, Go to this website for support phone numbers and too download manuals for this product. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
10helpful
How do I replace the staples in Stanley Bostitch B310HDS? I cannot seem to figure out how to open it.
"The staples load from the rear of the stapler. At the back end of the is a piece of black plastic that extends beyond the end of the stapler. This device holds the staples inside the stapler. To open the area where the staples are placed, push this extended button and lift up on it. The spring device that holds the staples inside the stapler will then slide out. Place a new strip of staples inside the stapler on top of the two metal guide rails. Then insert the spring device to lock the staples in place. The stapler is now loaded and ready to work. " hope this helps you out
2answers
I HAVE A BOSTITCH NARROW CROWN AIR STAPLER AND THE STAPLES ARE NOT GOING FOREWARD FOR THE ROD TO DRIVE THEM IN. IS THERE SUPPOSED TO BE A SPRING BEHIND THE STAPLES TO MOVE THEM FOREWARD. PLUNGER COMES...
There is a spring to push the staples into place. Bostitch was purchased by Dewalt and moved their parts lists to the web address below. Enter your model number and order the parts needed. Good luck with your future projects.
http://servicenet.bostitch.com/
2helpful
Door springs, part no. H286, for a Bostitch H2B stapler
10helpful
4answers
B310HDS Stanley Bostitch stapler rod to lock stapes has plastic t
I have the same problem and have found no answers from Stanley Bostitch customer service. They redirect to a telephone number that does not answer.
Solution: Don't buy Stanley Bostitch.
1helpful
How do the staples stay in place in my stanley 1/4" stapler? They slide back and forth and therefore aren't in place for the stapler to work?
There should be a pusher that is attached to a spring. If the spring broke, or the pusher is missing the staples will not stay in place.
If you can locate a model number on the tool, you go to bostitch.com to find the parts you may need
Top Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
