It was operated with partly blocked hose for five minutes
SOURCE: Hoover wind tunnel vacuum cleaner shuts off during use
Check the inlet down by the brush roll to make sure it isn't clogged. If not and the hose isn't clogged, then probably the thermo protector (part #28382093) maybe bad. It is mounted near the motor. Could be motor Part #43576188. But I would suspect a clog in the inlet or hose, or the thermo protector has gone bad.
SOURCE: 2004 Mitsubishi Diamante heat and Air blower motor.
OK... First thing it may be a (relay switch) they are cheep and installed in sec. Ok now if you dont know what one looks like then go buy one ol' rilley or pep boys or auto zone are somthing . while your there buying the relay talk to these people most of the time they are good at supporting people . So you may ask "hey can you help me find where this part is located" . Ask about the fuse to, once you get someone out there to help you . One thing I know for sure is you did look in the correct spots for these fuses but let me tell you worst case. Would be your heater switch is out. They are expensive and are only found at the dealer. I would recommend looking on e-bay if this problem comes to this. oohh if you cant figer out how to put one of these in then find a friend that is rely good at installing car stereo's Im sure you will win this problem.
SOURCE: Kenmore Dryer Mod. #110.68932792 Ser. MJ1907445
there is a motor relay in the consol part 3405281,there is also a heat relay too,you can swap em out to see if this is the problem, the one on right side with blue wires is the motor relay let me know how you make out
SOURCE: blowing fuses on blower motor 2006 e250 econoline
Both are possible.But it can be blower motor issue mostly.Its taking too load and that's blowing the fuse.How to Test and Replace
Blower motor on car?
http://repairhelpcenter.blogspot.com/2011/12/how-to-test-and-replace-blower-motor-on.html---------
How to Replace Blower
Motor Wheel?
http://repairhelpcenter.blogspot.com/2011/12/how-to-replace-blower-motor-wheel.html Also
more help solutions recommended. Click the link below :---
Blower motor replacing for all vehicles?
http://repairhelpcenter.blogspot.in/2012/02/blower-motor-replacing-for-all-vehicles.html
----------Blower
motor Resistor shorting problem?
http://schematicsdiagram.blogspot.com/2011/12/blower-motor-resistor-shorting-problem.html
--------This will help.Thanks.
It is possible that your dryer isn't
heating because its heating element is defective. Heating elements are
irrepairable. If yours has ceased to function properly, you will have to
replace it. Open your dryer's cabinet and locate the heating element so
that you can test it.
hermal Fuse
Another possible cause for a dryer not
heating up could be attributed to a faulty thermal fuse. Once a dryer's
thermal fuse has blown, it is no longer of any use. If your dryer's fuse
is blown, you will have to replace it. Open up your dryer's cabinet and
locate its thermal fuse so that you can test it.
Thermostat
If any of your dryer's thermostats have
become defective, they could be the reason that your dryer is not
heating. Open up your dryer's cabinet and test each of your dryer's
thermostats. If any are faulty, replace them.
Timer motor
A defective timer motor could also
cause your dryer to not heat up. Test your dryer's timer motor. If it is
no longer functioning as it should, replace either the entire motor
assembly, or just its motor.
