First you need the manual see what it is look for it in Google or company web.
Testimonial: "Brother, I already try manually but not working, please give me some suggestion how to fix ?"
Https://printcopy.info/index.php?l=en&mod=erc&brand=Sharp&model=MX4101N&code=E7-23
Different model Sharp with a E7-23 error:
Code
E7-23
Description
LSU laser detection error (Y)
Causes
Reduced laser power, lighting error, laser diode trouble. Harness and connector trouble between the LD PWB and the LSU cnt PWB.
Remedy
Use SIM61-1 to check the operation of the LSU. Check the PWB and connection of the harness in the LSU. Replace the LSU.
Testimonial: "Thanks for your information, but i already try this simulation code but no working...can you please give me another suggestion or guide line"
SOURCE: JAMSHED MY PRINTER GIVE THE MASSAGE LSU ERROR
i am not able to print as this model printer is not in system
SOURCE: our sharp mx-m450N gives us error code u2-11. what
EEPROM read/write error (serial communication error)
SOURCE: Our Sharp MX C311 gives
sounds like your NIC card is bad, no network cable plugged in or the network port in the wall is not an active network port.
