Refrigerators Logo
Anonymous Posted on Feb 08, 2019
HOTPOINT FRIDGE FREEZER FREEZER OK LOWER HALF OF FRIDGE COOL -TOP HALF IS NOT
MODEL XA085 T
Tony Marley
Level 2:
Habit-Forming:
New Friend:
  • Expert 87 Answers
  • Posted on Feb 11, 2019
Tony Marley
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
87
Questions
Helped
50832
Points
212
Check the back of the freezer is see if there is ice or frost on the back wall. This would indicate it not defrosting causing the problem. The other thing to check is if the fan in the freezer is coming on.
5 Related Answers
Anonymous
  • 247 Answers
  • Posted on Feb 28, 2008
SOURCE: Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Frank Chen
  • 330 Answers
  • Posted on Jul 10, 2008
SOURCE: My hotpoint fridge freezer model
check the fan
A
Anonymous
  • Posted on Aug 06, 2008
SOURCE: bottom freezer not working
Hi, sorry I do not have any advice to offer. We have the same model. Three weeks ago the red light came on and freezer stopped working. Last week the fridge packed up. We may have been unlucky but I thought it might be worth mentioning incase they were related and your fridge gave up as well.
Anonymous
  • 158 Answers
  • Posted on May 06, 2009
SOURCE: no cooling in refrigerator
air passage from freezer to the lower door maybe blocked with ice build-up
Anonymous
  • 1136 Answers
  • Posted on May 13, 2009
SOURCE: cool compartment is not cold enough
Hi, Have you noticed an ice or frost build up at all in the freezer section. Is the freezer holding a zero to 5 above temp?
I will try to help you though this. please let me know.
Thanks
Vic
Hotpoint Rfa52 fridge not working. Freezer ok.
is temp or freezer control turned all the way up? set frig / freezer control in middle and wait 24 hours. do you feel cool air going in freezer from vent? if not change control as stated and see if you have air flow. control door to frig may also be broken or stuck
1helpful
What causes the coils behind the panel in the freezer to freeze up and stop the freezer fan? top half of freezer defrosts, lower half stays cold.Fridge is side by side and freezer fan keeps turning of
When the evaporator fan motor stops running the top half of the back wall of the freezer will frost over and the the only reason the lower portion stays cool is because cold air falls. More than likely you have a a dc motor fan and its bad, but be wary with ge, the main control board could also go bad causing the fan not to run.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Diverter valve on Hotpoint FFA70 recieves no power, Fridge ok
Bonjour..Your system check (hot cold) is correct. Generally all new refrig/freezers cool only the freezer & bleed cold air off to cool the refrigerator. Most diverter/airflow dampers I have seen are mechanically operated for simplicity & to keep costs down. I would unload freezer and pull the panel off where you see the fan mounted. Go slow, don't drop any screws.You may not get them back. Look at the drain pan under the evap. coil. If it has ice that is built up in layers. Suspect the defrost termination thermostat. If the evap coil is clogged with heavy frost, suspect 1 the defrost timer and 2 the defrost heaters mounted on the evap. coil. Let me know how you make out.
Parts http://www.repairclinic.com/Refrigerator-Parts?s=t-Hotpoint+FFA70-%3d%3da4&z=50
1helpful
I have a westinghouse 2 door fridge that is not getting cold enough, 7 degrees in the fridge, freezer seems ok. not sure where to set the controls as i have no manual. its a 2 door,freeze at the top and...
i think your ref working normal try to adjust thermostat setting on the fridge if you want to cool lower than 7 degrees but this temp. allready can chill the food. then you said that freezer ok.
Fridge/Freezer - fine bottom half, warm top half
Sounds like the fan in the freezer is not working ( pt# WR60X190 ) .
My Hotpoint FFa70 - Fridge acting like a freezer!! Freezer ok!!!!
Check your settings. Each compartment has its own and lower settings to at least the half way point from highest.
Top half of fridge and freezer are not working
I need that model number of the Frigidaire refrigerator so I will able to help you better. Thanks, Sea Breeze Here is my email should you not be able to contact me. [email protected]
2answers
Bottom freezer not working
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
