Battery is dead pull cord is stuck
SOURCE: Starter cord loose on Bolens 4.5 HP lawn mower
Need to remove the pull cord assembly. Something is amiss in there. If you don't want to attempt it, I'd take it to a shop.
SOURCE: Toro Electric Start Mower Barely Turns Over
this is easy to point out the problem. if it is still under warranty get warranty replacement of the starter is not you might be better off just buying a new mower might be easier and cheaper because if your not still under warranty with it it will cost you quite a bit of money if you can't replace it yourself it will cost you the amount of the new starter and it will cost you the amount that the shop's labor fee which can vary a lot depending on where you take it.
SOURCE: I have a Toro electric start 22
It sounds like the starter drive may be jammed. It should not be engaged unless you are using the starter motor. Take the spark plug wire off, put on heavy leather gloves, and try turning the blade by hand to dislodge the starter drive. If it does dislodge, plug the spark plug wire back up and try the pull start again.
Testimonial: "The expert who helped me knew his onions. His diagnosis and advice was flawless. I followed the instructions and problem solved. Thanks a million!"
SOURCE: Electric start on 640 pulls dead
put bike into 2nd gear while on the bike and push backwards until the bike goes no further.put back into nuetrual.should start easier.works on my 640 when its slow to start
SOURCE: I have this Toro trimmer/edger.Can't pull the starter cord
you must take apart the cord recoil and rewind the pull string,inspect string make sure its the same thickness through out if not replace it, not too hard i believe you can do it.
