Sewing Machines Logo
Gillian Greenwood Posted on Feb 08, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sewing machine has jammed - how do I fix it?
The machine jams when I turn the control to the point at which the needle is at the high position
  • CJ Rock
    CJ Rock Feb 08, 2019
    Please add make and model in the comment box?
Matthew Minton
Level 2:
New Friend:
  • Expert 58 Answers
  • Posted on Feb 08, 2019
Matthew Minton
Expert
Level 2:
New Friend:
Answers
58
Questions
Helped
32124
Points
160
You might won't to pull it out and make sure it did not get bent on the downstroke that will jam it up every time might have to get a new shaft
  • Matthew Minton
    Matthew Minton Feb 08, 2019
  • Matthew Minton
5 Related Answers
Anonymous
  • Posted on Feb 28, 2008
SOURCE: needle jam
stuck the whole machine the needle did not move .needle and wheel handle both are stuck
Anonymous
  • Posted on Aug 07, 2008
SOURCE: bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
A
Anonymous
  • Posted on Aug 20, 2008
SOURCE: Brother CS-6000 Sewing Machine - Jam
I had the same problem.. I think the bobbin used in this machine is no good I replaced mine.. It cost alot too.. but now I do not have any problems.. good luck
Anonymous
  • 25 Answers
  • Posted on Jun 02, 2009
SOURCE: sewing machine jammed wheel will not turn
Thread is caught in the hook...Remove the upper thread and bobbin case...turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
Anonymous
  • 11 Answers
  • Posted on Jun 16, 2009
SOURCE: janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
Sewing machine is jamming on first turn permanently
Your bobbin may be in backwards. Is it possible to put it in either way?
Messages about safe device activated & press the needle position button
The noise is because the machine is trying to raise or lower a needle and can't move. Several things to check. Did the needle break and jam in the bottom thread? Is the needle bent or jam? Did the thread jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom carefully cut the threads until you can free the hoop and material. Then check to make sure all pieces of thread and fuzz has been removed in the bobbin case. If it happens again check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping.
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
2helpful
I was sewing, turned the machine off to pin something, and when I turned it back on, it jammed in the bobbin area. It will only stitch one stitch and then jams. I have taken it apart over 30 times, and...
have you tried changing the needle-
1.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
check the thread take up lever-if the thread come off the thread take up lever that will jam the machine up--I've had it happen to me
I have a singer cxl electronic sewing machine and i have a problem with the needle either not moving or stopping when stitching the larger motifs or the zigzag stitch, somtimes the needle jut moves too...
The needle either not moving or stopping is a sign that the machine is jamming. Here's the answer for the question "My machine is jammed" from the FAQs on Singer's web site at http://www.singerco.com/support/faqs.html
A jammed machine is caused by thread being caught in the hook. Remove the upper thread and the bobbin case, turn the hand wheel towards you (counterclockwise) by hand and remove any thread in the bobbin case area. *Always turn the hand wheel towards you. Turning the hand wheel away from you (clockwise) can cause the machines timing to become unaligned and jam your machine. Also, always make sure the presser foot is in the down position before you start sewing. Sewing with the presser foot in the up position will jam your machine in the bobbin case.
Your description of the needle hitting the plate or foot is an indication that the machine's timing has become unaligned which can be caused as indicated above by turning the hand wheel away from you - the correct way is to *Always turn the hand wheel towards you.
Janome mylock 634D overlocker
9helpful
2answers
Bernette 90E
Our Bernette E90 timing was off due to a jam (design flaw I think)...Instructions on how we fixed it.
1. To correct timing, tip over machine and unscrew inspection plate.
2. Find the gear and unscrew the 2 grub screws so the gear is free from the shaft
3. Turn the main sewing machine handle to manually get the hook (pointed piece) of the housing (see arrow) to be directly behind the needle
4. Hold it the tightly, and turn the handle again, the needle should be able to go up and down while holding the hook in position.
5. When the needle is at it lowest and starting to move back up and the hook is directly behind tip the machine over and tighten the 2 grub screws on the gear underneath.
6. Replace inspection cover and you’re done
Jammed
ROLL THE MANUAL LEVER BACK AND FORTH WITH CONTROLLED FORCE till the needle comes out! the jamming is caused by threads tangled inside the bobbin area. rolled it with a controlled force back and forth. when the needle comes out flip your machine to where you could open the bottom part and remove/clean the threads tangled on the bobbin!
place some OIL.
1helpful
Thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
