WHEN I WANT TO RUN A COPY, IT DOESN'T WORK AND THE ONLY INSTRUCTION I GET FROM MY PRINTER IS CHECK THE SCANNER
SOURCE: scanner bulb doesn't turn on during a scan
You can try to get and replace the scanner light. If it was the light, the new one will work. If it was some other electonic component that shut off the light, then the light won't work. Depends on the cost of a new light compared to getting the unit serviced by a tech. Or the cost of a new Multifunction unit. Do some research before you make the decision.
SOURCE: My F4280 has blinking on
The product uses various combinations of flashing lights to indicate its current status.
Issue
The Check cartridge light is blinking.
Cause one
The cartridge door is open.
Solution one
Make sure that the cartridge door has been completely closed.
Cause two
The cartridge is missing or not seated correctly.
Solution two
Insert the cartridge by sliding it forward into the slot correctly.
Cause three
The tape was not removed from the cartridge.
Solution three
Make sure that the plastic tape has been removed before inserting the cartridge into its slot.
Cause four
The cartridge is not intended for use in this product.
Issue
Cause one
Solution one
Cause two
Solution two
Cause three
Solution three
Cause four
Issue
Cause one
Solution one
Cause two
Solution two
Cause three
Solution three
Cause four
Issue
Cause one
Solution one
Cause two
Solution two
Cause three
Solution three
Cause four
A quick fix for most communication errors can be achieved by
resetting the printer and/or rebooting the PC. Simply disconnect the printer
from your computer (if USB connected)> reboot your pc > unplug and
re-plug the printer into the power source to reset it. When the printer turns
on, reconnect it to your computer (if USB connected). Then try to print again
once the computer fully recognizes the USB connection or when the WiFi light on
the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
