Question about LG Televison & Video
I have an LG 60LB7100 TV that turn on full bright for 10 sec. and then goes dark but you can faintly see ..
SOURCE:
  • 556 Answers
SOURCE: Picture goes dark
1 your problem is in video section 2 if it is ok then check power supply for any components defective.
Posted on Sep 16, 2007
IrishDruid
  • 2712 Answers
SOURCE: lcd tv screen has gone
1. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
2. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic (not same model):
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 03, 2008
SOURCE: faint green discoloured screen then screen is blank
Sounds like one of your florescent tubes have died. THe power circuit is trying to start it but fails then shuts down
Posted on Jan 11, 2009
  • 16 Answers
SOURCE: LG Projection TV has dark picture
To do this, press the ENTER button on the TV and the MUTE button on the remote at the same time. After 5 seconds the screen should come up and it will read "Lamp use time...Total lamp use time ....lamp reset" Press the center button on your remote (the circle button right in the middle of the four directional buttons) and you will be reset to -0- again. Your orange light should now be off.
Posted on Feb 02, 2009
benwabnick
  • 2404 Answers
SOURCE: moniter flashes on, then goes dark. help please!
Sounds to me like its either the inverter or the lcd. If you can get the monitor apart go ahead and reseat the lcd cable cause it could be that the cable came loose during the move, it could be halfway in and halfway out.
After you do that see if the monitor works then, if not then try a different monitor on the computer, if you still get dim video with the known good working monitor then you know that the video card is bad.
If you get a good picture with a known good working monitor then you know the original monitor is bad.
Keep in mind that LCD's are sensitive and even if they get slightly hit, it could be enough to knock them out of commission.
Posted on Jul 02, 2009
LG 60LB7100 was hit by a power surge(lightning) now it turns on but won't go passed the opening screen
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 24, 2015 | LG Electronics 60LB7100 60 Inch 1080p
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
Colour is not normal, sometimes the picture is too dark, football pitches bright green, peoples faces very orange.
that would be a failing tcon board on the back of the screen.you would need to replace this part but they are available on ebay the part number is on the tcon board. match the numbers a version number to get the matching board for the screen. tcon board is the board were the main wire cluster goes to the screen board this is the tcon board.
Jul 03, 2017 | Samsung LE37R72B 37 in. HD-Ready LCD...
My lg tv has sound but no picture appearing,what seems to be the/ problem
When the picture goes out again, dim the lights in the room. Take a bright flashlight and shine to on the screen, do you see a faint picture?
Feb 02, 2013 | LG 32LG30 32 in. LCD HDTV
Olevia 265TFHD 65
FIGURING OUT YOUR PROBLEM IS ONE THING, BUT FINDING THE PARTS WILL BE THE BIGGEST CHALLENGE. I HAVE A OLEVIA 255TFHD AND IM CATCHING HELL FINDING PARTS. SYNTAX BRILLANT, THE COMPANY THAT MADE OUR SETS HAS GONE OUT OF BUSINESS. PARTS ARE SCARCE
May 11, 2012 | Olevia 237T 37 in. LCD TV
I have no picture on my 15" LCD Insignia TV. My
You may have a burnt out blacklight... You can fix it easy by having the tv on while it’s a bright picture than quickly unplugging it... or it would be best to get a new TV.
Oct 27, 2017 | Insignia 15 in. Flat Panel LCD HDTV
Large dark shadows on display,but the menu can be seen faintly,and no control over brightness but overall brightness low.The electronics is functioning o.k, but the dark shadows block out all images...
Sounds like a Z-SUS board. This board "erases" the picture between frames and prepares the screen for the next frame. If it goes out, your picture will be very, very dark. As for the reason... It's electronics, they just break. If you want to attempt the repair yourself, you will need to post the full service model number. ex: 50PC3D-UE.SUSLLJR Otherwise, we can't get you the correct part number for the Z-SUS. I hope this was helpful.
Apr 16, 2010 | LG 50PC3D 50 in. Plasma Television
Approximately 2/3 of the screen is dark. this started about six months ago and is progressively becoming worse. when problem began the screen would recover to full brightness after it was on for 30...
Hi there...it is sounding like a backlight is going/has gone out...these can be proffesionally replacedat a repair shop...To self diagnose if it is the backlight take a flashlight and, with tv on and while on a tv channel and carefully form different angles look into the 'dark' part of the tv screen...if the/a backlight on a lcd tv/monitor goes out(even laptop screens) then u can still see a faint image with a flashlight(or without one with a good eye)....If you still see the (tv channel) image, then it is most likely a bad backlight......
I hope this helped you some, if it did(or not) please rate!...Thank you
Apr 16, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
Steve Allison
Steve Allison
