EDENPURE USA1000 Infrared Heater Logo
A
Anonymous Posted on Feb 05, 2019
Eden Pure heater gen 4. Why doesn't it run?
When I plug it in it it lights up beeps 6 times then will not run
2answers
What causes it to shut off?
I found nothing... iHeater 1500 Advanced...
(MY fault: strongly suggest the TELEPHONE)
Try
officialiheater.com
http://officialiheater.com/
or follow contact instructions (below)
Please be sure to read and follow all of the service
procedures outlined in this owner's manual. If you have
any questions concerning your iHeater, contact the
iHeater Customer Service Department at 1-800-469-0456
1-800-469-0456
iHeater, LLC.
5789 Park Plaza Court, Indianapolis, IN 46220
www.officialiheater.com
Carnac the Magnificent
Sahara big burn patio heater
From the Troubleshooting Guide - Check the Obvious Turn on the gas and listen at the burner to see if you can hear the gas arriving.
If the patio heater has an electronic ignition system make sure that there is a spark. If there is a spark but the heater will not light up, try using a lighter or burning spill to light the gas. Be ready for a flash over if you have been trying to light the gas for a while-there might be a small cloud of gas near the burner.
Start at the Bottom The most likely reason that a gas heater will not work is that there is no gas. Take out the empty gas cylinder and replace it with a full one. Often you will feel that there is still gas in an empty cylinder but there is not enough to create the pressure needed to drive the gas burner. An empty cylinder will feel light.
Check the Gas Regulator The gas regulator is the connection of the gas cylinder to the gas pipe that takes the gas up to the burner. Some regulators have a flip switch that prevents the valve in the top of the cylinder from being depressed-effectively an "off" switch. If there is such a switch, make sure that it is in the "on" position.
Check the Gas Pipe Although it is most unlikely that the gas pipe can get blocked, remove the gas pipe from the regulator and from the gas inlet at the top of the heater. This pipe is pressure fitted and held in place by pipe clips. Blow air through the pipe to ensure that it is clear.
Check the Burner The burner will be a very simple assembly. Take each part off in turn and check for any blockages. Also check that the burner apertures are set correctly. Beneath each burner is a small chamber in which air and gas are mixed. Make sure that the gas and air inlets are clear.
If Your Heater has a Pilot Light If your heater has a pilot light, there is the possibility that the thermo couple has failed. The thermo couple is usually shaped like an inverted "v" and sits in the flame of the pilot light. The temperature acts on the thermocouple to keep the gas supply to the burner open. A good indication that the thermocouple has broken down is that the pilot light goes out when you try to turn the heater on. Thermo couples are readily available patio heater parts and usually available from stock.
If you have carried out all the checks and the heater will still not light, you can repeat all the checks more slowly and carefully or take your heater to a specialist for a service.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
3helpful
2answers
I have a I heater that will not turn on. Last time it worked fine. What should I check ?
first check the outlet its plugged into to be sure there is actually power there, if not check your breaker box, it may have overloaded the circuit and popped the breaker. if all good there, check the unit for a fuse, which may be blown.
My infrared heater home heater makes a screeching noise
That will be the fan and dry bearings on the motor. Spray with WD40 which although is a Water Displacement spray, it will do the job.
My fahrenheat fuh-54b won't stay running long enough to heat
Most likely defective thermostat or heat sensors on the unit
2answers
My pro temp dual propane burner heater will light but won't stay lit
Either the temperature probe (at the pilot light) that signals the gas valve to open is defective or the gas valve is.
Heater runs 1 cycle then turns off
Replaced 301 80C 16A thermostat, purchased on ebay for $6.00, fixed problem. to Fix standing at front, Remove left side panel, two small screws hold thermostat in place. LifeSmart wants $36.00 for same part. Fixed problem.
Eden pure beeps 3 times, and then it will not work
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board.
Top EDENPURE Patio Heaters Experts
deton8 von Splosion
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you an EDENPURE Patio Heater Expert? Answer questions, earn points and help others
