Heating & Cooling Logo
I am looking for Comfortec c60tnpj fireplace owners manual. Please help.
Pilot is on, wall switches for both ignition & fas have been changed out. Still get NO flame when wall switches are turned on.
Heat & Glo ' Install & Owners Manuals
www.heatnglo.com/Owner-Resources/Install-and-Owners-Manuals.aspx
Each fireplace, stove and insert has a rating plate which contains your model number and serial number. Gas and wood burning fireplaces have a rating plate in ...
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition ...
? 2:21
www.youtube.com/watch?v=_-8dY8tUGhw
Aug 24, 2012 - Uploaded by HeatandGlo
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition System Video ... Relighting Your Heat & Glo® Standing Pilot FireplaceVideo - Duration: ... How to Install Your New Gas Log Set - The Fire Place - Palm Desert - Duration: ..
36ECMII pilot light won't light
If you go to this link http://fmisupport.hcents.com/supportdocs/54024F.pdf it will take you straight to the owner's manual.
Now the gas log set is completely seperate from the fireplace. You would need to find out the model of the gas log set as any manufactuer of vented gas logs can go in this fireplace. Just for clarification the brand is actually Coleman but it was made by FMI. Now, the SPVBPD is a direct vent gas log set that was only designed to go into either the Amity, Oxford, or Victor hearth gas stoves. If you have the SPVBPD burner in a 36ECMII then you honestly need to remove that log set, as it was a burner only rated for direct vent fireplaces, and get a set of 18" LP vented logs. If you look at the link below you will see the owner's manual for the SDVBND. These logs need to be removed and you can go with any 18" vented log set. I suggest Peterson (http://www.rhpeterson.com/realfyre/vented-series/)
as they have the widest selection of logs and biggest array of dealers. Good luck.
Desa Tech SDVBND Owner Operation And Installation Manual
I am needing a new blower for Charmglow propane ventless fireplace #cgn300tq
I can't find an owner's manual anywhere for this fireplace, but you are welcome to see if any of these universal fan kits look similar: Universal Fireplace Fan Kits.
1helpful
I am looking for a manual for a Security Fireplace Model SRGH36R can you tell me where to get one??
Security Fireplace ceased manufacturing gas fireplaces almost 8 years ago. So, finding an Owners Manual for your model would be almost impossible. Although, if you can locate a hearth (Gas fireplace) dealer in your area, that did sell them at one time, they may be able to help you.
Sorry I didn't have better news for you.
I need operating instructions for a Royal Fireplace.
The following link is to the Owners manual for your wood burning, Heat & Glo, Royal Fireplace.
You can download and print the entire manual.
http://www.heatnglo.com/~/media/Files/Heat%20n%20Glo/Installation%20Manuals/4044_153.ashx
Hope this helps to get you safely up and burning.
Please let me know.
1helpful
Need to replace noisy fan motor on Dimplex 6901470100 Not sure how to gett access to blower. Thanks
If you no longer have your Owners Manual go to the Dimplex home page and click on the Help tab. You should be able to download the Owners Manual for your model fireplace there in a pdf format. Also look for a Trouble Shooting tab.
Receiver was beeping... Jiggled it ... Stopped beeping... Now not working ...tried to reset transmitter with receiver but will not work .... Did replace batteries and recharged receiver as well ... Remote...
There's no quick answer to your problem, as it may be your gas fireplace that's causing the problem. If you still have your Owners Installation Manual look at page # 7 (Trouble Shooting), this should help you solve your problem. If you don't have your Owners Manual, you can download it online from SkyTech's website. If all else fails contact SkyTech's Technical Service Dept @ 888-672-8929
They are friendly and knowledgeable folks to work with.
2helpful
2answers
I recently bought a house w/ a Marco gas fireplace and there is no owners manual. I have never used a gas fireplace, so I have no experience with this. I would really like to get an owners manual, but...
www.macro-fireplace.net is the manufacture's website where you can request a manual for free.
I haven't located any others but I will keep you posted if and when I find one.
Top Heating & Cooling Experts
Paul Carew
john h
