Washing Machines Logo
Posted on Feb 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi all, my AEG L89690FL takes a long while to fill. I’ve checked the tap, the hose and cleaned the filters. Error message is check the tap. And occasionally it self pauses. HELP!
Level 3:
  • AEG Master 19,187 Answers
  • Posted on Feb 03, 2019
AEG Master
Level 3:
Answers
19187
Questions
0
Helped
4339511
Points
82259
This could be the valves not opening all the way that could be due to mineral buildup, check the water pressure in the line and also check to make sure the proper voltage is getting to the valves and if all is ok, replace the valve assembly from any online spares centre.
5 Related Answers
douglas smith
  • 1462 Answers
  • Posted on Mar 19, 2007
SOURCE: "Check Water Tap" error
rinse valve possibly open circuit or external water pressure low
Anonymous
  • 1865 Answers
  • Posted on Jun 01, 2009
SOURCE: AEG 62600 Will not fill. Hose from tap is clear. Help
Try filling with hot and cold water, the water valve solenoid may have failed.
Anonymous
  • Posted on Jul 01, 2009
SOURCE: I get a check water tap error 2 to 4 times a load
I have this problem. This code is due to restriction of water flow. In my case, we have sand in our water, and I have installed a filter between the water line and the washer. When it gets clogged, the flow is restricted and the Check Water Tap message appears. Your washer has filters on the back of the washer itself that may be clogged and need cleaning (which is why I installed the water filter between the washer & water line to prevent it from getting into the washer filter). Your washer manual shows you how to check/clean them. Also, you may have low water pressure during summer months due to lawn watering in your area that could cause this lower water pressure.
caroldon
  • 17130 Answers
  • Posted on Jan 22, 2011
SOURCE: LG F1406TDSP6 Washing machine starts
It can be that the drain pump is consuming more currrent than is required from the board as the processor senses that this is a malfunction and so shuts down as a safety mode.
So recheck on your drain valve/pump . test from the outside. If not the fault can be failure of the pump driver in the main board causing the error related to the drain pump.
Check the main board .
BElectric
DILLIGAF
  • 1140 Answers
  • Posted on Apr 16, 2011
SOURCE: I have error E:15 with
Hello Gary,
You didn't specify the brand or model number of the dishwasher, but I suspect it's a Bosch, in which case the E:15 error with the flashing tap sign and the drain pump running continuously means the anti-flood protection system has been activated. This could be due to water having leaked into the bottom of the washer under the tub or it could be as simple as a stuck float or faulty float-switch.
If the drain pump is running whenever there is power to the washer and continues to run even with the door open, this means the anti-flood protections system has been tripped. You then need to determine whether this is due to a leak or a faulty switch . . .
First remove the kick-plate from under the door and check for any signs of water having leaked under the tub. If there are no signs a leak, the float-switch is either stuck or needs to be replaced.
The position of the float-switch will either be near the front right corner or the center of the washer depending on which model you have. If your washer has a 'mushroom' in the base of the tub near the center, try lifting and dropping the mushroom a few times to make sure it isn't stuck.
If you don't have a mushroom, the float and float-switch will be near the front-right corner. You will need to pull the dishwasher out from under the counter and remove the left-side panel to get access to this. The float switch assembly will look similar to this:
I've ringed the switch in red and this is activated by the red lever running vertically below. You need to make sure the switch clicks on and off when you raise and lower the red lever. If the switch is stuck on it will need to be replaced
Please try this, then let me know if you need further assistance. You can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
2answers
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
My AEG OKO LAVAMAT 72640 keeps stopping mid cycle and flashing error cod E10 what can I do?
The water Supply
1. First, check that the tap is not accidentally turned off.
2. Check that the gray water inlet hose is not squashed or kinked lies.
3. It is also possible that the filter is clogged in the supply hose. Close the tap and disconnect the hose. Here is some pressure on it, so keep a towel handy. Check the filter that output waterklraan, and clean it if necessary.
3answers
What does error code ie indicate?
IE error mostly means not filling completely with water or very slow fill
Came up on display f10 and wont work
Hi dear,
F10 error related to OVER FILL. Follow the things below,see how it works.Thanks.
Troubleshooting
Error messages If an error occurs during the program, a message
is shown on the display. To exit the message after
taking action, turn the machine off and then back
on.
The error messages that may be shown in the
display are:
F10 Overfilling
1. Shut off the water tap.
2. See "Drainage error".
F11 Drainage error
Check:
• that no objects are stuck in the drainage hose
outlet.
• that the drain pump is not blocked by foreign
objects. Clean the pump. See the "Care and
maintenance instructions" chapter.
• that there are no kinks in the drainage hose
After taking action, run the Drain program or press
the Door Opening button (key symbol) to empty
the machine. If this does not resolve the problem,
call the Customer Care Center.
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
I have water out of both taps when hoses are disconnected. when i connect back to taps. select cycle machine wont fill. i have turned taps fulled on with no success any ideas please... is there a reset...
(this I've pre-typed!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
2helpful
Hi i got a hotpiont wt960 and i'm getting the h2o error. water is coming through the inlet pipe and the pressure is fine. i've replaced the water filter aswell as the pressure switch
Sorry- this is my 'standard' reply to water fill/H2O problems- hope it helps!
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
John C
AEG L76650 Front load washer. Approx 2 years old - set programme -ok, Press start button it appears to switch on, there is some start up sound but it doesn't move to fill with water. No problems on...
John C
3helpful
Aeg electrolux error message E20 has just flashed up during drying cycle. What does that mean? Had to turn washing machine off and on again to get washing out
it might refer to any blockage in the water supply. So cleaning the pump could primarily resolve this. but it might also be a blockage in the soap tray (when available), the tap or the hose attached to the tap or the air-gap or any water control structure. but most of the times, it is simple blockage of pump. just pull out the manual, remove, clean and replace the pump. this will solve your problem.
cheers
Top AEG Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
