Jack lalane power juicer express...will not turn on
SOURCE: Jack LaLane Power Juicer CL003AP Tri Star Products
The Jack Lalane website claims it has a lifetime engine warranty. Visit to find out.
SOURCE: Taking apart Jack Lalne power juicer to clean.
There are two holes on the surface of the blade. When the juicer was bought, it came with a half moon shaped orange tool that has two posts that fit into these two holes.
By inserting the tool into these holes you can unscrew the blade from the machine as long as you hold the outer screen while doing so.
Once this is done, you simply lift the other pieces off.
If you can't find your orange two prong tool, i would suggest using a screw driver or two that fit into the hole(or two)..... hold the orange screen and turn the blade counter-clockwise..
Hope this helps
Smitty
SOURCE: how do you disassemble the jack lalane juicer?
You use your Orange cresent tool with the 2 metal thingies on the bottom of it. Take off the top of the juicer. Then get the tool and then stick the tool where you see the two holes. Hold down the spinning like grater, and use the tool to turn counter clock wise. Once you do that the Middle part will come off.
SOURCE: jack lalane juicer
All in the name of health I said a lot of bad words, except that I know I never toss out my owner's manuals. I finally went to find my juicer model number when I noticed that the box said that it came with a recipe book (!) so I ran to my recipe book cupboard and sure enough the owner's manual was with it. (Maybe yours is there..)
Anyway, the key is this "crescent wrench." Doesn't look like a normal crescent wrench at all, but the handle is shaped like a crescent moon. It has two little pegs that stick out and fit into the two holes in the top of the blade, Then it twisted counter-clock-wise, the blade **still screwed into the piece underneath it, then it easily comes out, as do the other parts inside. It was just that rotten little "wrench" piece WHICH, I might add, is unique to my model. If you download the other owner's manual that's online, it doesn't mention any such tool for their model. (sorry, I can't find a model # for mine. There is a "V3 52803" on the back of the manual if that's the model.) Good luck. Hope this helps you. Happy, and healthy juicing.
p.s. in the end...it's all about Jesus.
