Washing Machines Logo
A
ANITA KING Posted on Feb 02, 2019
My hoover F7411900 doesnt work on wash .doesnt put water out
But if i put on rinse it works like it should
5 Related Answers
douglas smith
  • 1462 Answers
  • Posted on May 04, 2007
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Anonymous
  • 1673 Answers
  • Posted on Jan 18, 2008
SOURCE: hoover 500 top load washing machine - water in-flow very, very slow
Check the water valve. Most of the hoses that are hooked to the water valve have a screened filter, turn water off, unhook hoses, check to see if they need to be cleaned. Other wise the water valve is bad and will have to be replaced.
Anonymous
  • 351 Answers
  • Posted on Mar 02, 2008
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
timer or timer module fault
Anonymous
  • 228 Answers
  • Posted on Aug 12, 2009
SOURCE: Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Anonymous
  • 3 Answers
  • Posted on Apr 25, 2010
SOURCE: hoover optima hnf6167 7kg washing
My washing machine completes its cycle but is leaking water from the left hand side on to the floor, Why is this???
1helpful
Hoover F7411900 was full of hair.cleaned out filled soap and water not spraying but suction good not sure what else to do
suck up some warm clean water while moving the wash rinse button back and forth thid will unplug the hoses if that dosent work replace the switch
I have a model f7411900 steam vac from Hoover and it started making a loud noise like a broken belt does in a vacuum. Does this have a replacement bely
Open the product, make sure first that it is not something stuck inside. If it is a belt, check with amazon. Just make sure that you have the correct model.
Brushes on my hoover spinscrub model F7411900 wont spin
vanger cheva in post 1 got the correct answer. I just disassembled my f7411900 with some difficulty and took the turbine apart. Sure enough the bearing on the shaft was froze from rust. I was able to free it up in a vice and screw driver big enough to grab and turn the middle of the bearing. I used 3-1 oil and it now is smooth again. Not sure for how long. It was then I found the instructions by vanger above. There is no belt in this unit. The turbine is driven by water that turns the brushes.
What setting do I need to have the machine on to **** up the excess water? I want to download the manual but can't seem to find a link to do so, how would I do that?
You should have the vacuum set to Wash/Rinse for all steps in cleaning. Press the trigger to release the cleaning solution and push the vacuum forward. With the trigger still pressed, bring the vacuum back towards you). Then release the trigger and again move the vacuum forward and then back. Repeat the "dry" strokes until the dirty water enters the dirty water tank. Watch the water going through the dirty water tank lid. Empty the dirty water tank if the suction fails or the tone changes. Do more dry strokes after cleaning the entire surface until you do not see more water entering the dirty water tank.
The manual is available from Hoover at the product site: http://hoover.com/products/details/f7411900/max-extract-dual-v-widepath-carpet-cleaner/ . The direct link is here: http://hoover.com/file/592/ .
I hope this helps.
1helpful
F7210-900 Steam Vac. will not put out water when switch is in wash position but it will put out water when the rinse position
There are two electrical solenoids inside the hood assembly. One opens to dispense rinse water, and the other dispenses the soap and water solution. It is likely that the soap and water solenoid has failed and will require replacement. A "work around" fix for this is to mix the soap solution in the clear water tank ( 5 oz. of shampoo per gallon of water ), and shampoo that way until the solenoid can be replaced.
My hoover washing machine won't spray rinse or deep rinse on cold
Rinse cycles are normally with cold water only.
I believe you have a faulty cold water inlet valve. To confirm, put the machine on a cold only wash cycle, and see if it fill up with water.
If it does, then the valve is O.K. In that case the problem you are having with the rinse cycle is most likely a timmer fault.
Good Luck
Ash
Water not getting to powder dept
SMALL SPRING HAD COME LEVER THAT IS CONNECTED TO WATER RELEASE VALVE , RECONNECTED SPRING AND EVERYTHING SEEMS TO BE WORKING OK .
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
