SOURCE: unbalanced load cabrio top loader
i am on line now- we checked with a level and its right on... i have been washing on the normal cycle and then using the drain/spin cycle to spin out as much water as i can..that cycle even displays the ul code...its always displayed somewhere between 12 mins left and 7 mins left...i dont know if that has something to do with it??
The Topload whirlpools are designed to take the lint out by reversing the water to drain out.any lint should be drained out.
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
SOURCE: Where is the pump/filter located on my Kenmore Front Loader Washe
It is just behind the lower panel. Remove the 3 screws from the lower panel (the panel just below the door), the screws are on the lip on the bottom of the panel facing the front of the machine. Pull down and toward you to get the panel off. The filter and clean out are in the center. Unscrew the cap to remove and clean out, but have lots of towels ready, there will be water coming out.
SOURCE: Water is leaking onto the floor underneath my
If its a small intermittent leak from the front left corner its the tub ring, whirlpool has redesigned the tub ring to fix this concern..
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5
minutes to pump out the water to a point where the pressure switch resets. To
solve this problem make sure that the drain filter pump assembly located inside
the bottom front panel is clean and after cleaning if the error returns then
the pressure switch needs to be tested and if bad then it needs replacement.
Please get back to me if you have any other questions.
Kevin
