Washing Machines Logo
Roger Mendoza Posted on Jan 31, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to repair the inlet sensor switch of AEG BS-45 model? I think the magnet fails of the sensor switch?
Pieter Vleeshouwers
Level 3:
  • AEG Master 2,029 Answers
  • Posted on Mar 02, 2019
Pieter Vleeshouwers
AEG Master
Level 3:
Answers
2029
Questions
0
Helped
4113583
Points
7389
Maybe it helps something
https://www.manualslib.com/products/Aeg-Bs-45-3977008.html
1 Related Answer
fordexpert
  • 5692 Answers
  • Posted on Oct 07, 2011
SOURCE: I have a 46" Yard Man riding mower with 20 hp BS.
Hello, Ask your local Mower shop if they show a Thermal switch for the PTO. You may have to replace it or move it away from the heat.
My old tankless naturMy gas water heater Bosch model JSRZ 5-T PG, it is not starting automatic it has magnetic sensor valve in water inlet
The Bosch JSRZ 5-T PG tankless gas water heater may not start automatically because of problems with the magnetic sensor valve, power supply, or control unit/thermostat. Possible troubleshooting steps are:
  • inspect the water inlet valve and replace if faulty
  • confirm that power to the unit is functioning
  • if the problem continues, seek professional repair service.
AEG OKO-LAVAMAT 86760 UPDATE 6KG C1 on I blew the 2 pressure tubes-clear Water supply strong Start again-just water from spin cycle out What to do next
C1 - means that in prewash cycle no water inlet, valve does not open/ interruption or flow rate too low.
So I suggest to you following: check water inlet, clean sieve, check inlet valve, check pressure sensor and finally check wiring.
Dado
Have a aeg oko lavamat 88730 update runs for short time then shows C1 what is wrong with it and how do I fix it and how much
C1 is fault in prewash cycle and means no water inlet.
Could be: vaIve does not open or interruption, flow rate to low.
So, I suggest to check an following parts: water inlet, clean sieve, inlet valve, pressure sensor, wiring.
Dado
AEG OKO FAVORIT 40300 When switching dishwasher on no water is flowing into the the dishwasher?
It should first be checked for correct water inlet hose with safety valve. After connecting the double-walled water inlet hose, the safety valve is next to the tap. Therefore the water inlet hose is only under pressure while the water is running. If the water inlet hose starts to leak during this operation, the safety valve cuts off the running water and the draining pump in the dishwasher is switched on. If the inlet hose with safety valve working correctly than could be some of following faulties.
  • The door of the dishwasher is not closed properly.
  • Mains plug is not plugged in.
  • House fuse in defective.
  • In the case of dishwasher models with start delay
    timer: A start delay is selected.
If you look at the lower electrical diagram then you can see that all electrical components are located in a circuit inlet valve which can be also faulty.
  • ON/OFF Switch
  • Door switch
  • Program controller (Timer)
  • Pressure switch
  • Inlet valve
  • Float switch
  • Wiring between all this components
Dado
Aeg 60870 dishwasher water not getting in. Error code.10
The most common cause of a fault "i10" is closed valve on the water supply line. So this failure indicates a problem with filling of water.
Possible error causes:
Closed water tap, Inlet valve faulty, inlet hose bent, softener system clogged, pressure switch or pressure switch hose obstructed or leaking, wiring from pressure switch to printed circuit board (PCB), wiring from inlet valve to PCB and finally PCB.
Dado
Aeg favorit dishwasher not filling with water
Dado
1helpful
Washing machine aeg 64840
Remove the line to the water level sensor, release the vacuum and it might solve. Also check inlet and drain blocks.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
1helpful
2answers
Anti flooding on aeg 64840
Problem was answered earlier. Please check the water level sensor, check the line , remove and reset. Also check for blocks in the INLET and DRAIN filters.
Aeg dischwaher model oko favorite
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Top AEG Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
