Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals and it's verrrrry cheap and mine
I got free in offers
3rd time I also had an issue with
the file so the girl replaced it in 30 mins
there is one more but i don't remember its name it was 2 years back bitman something link this
Try it out brother
SOURCE: need to replace rear suspension for 90 senra
Yes! If ya dont have a good spring compressor, and ya take the center nut out.. It'll kill you as the spring/shock separates.. My advice is to watch one being done before attempting.. Thanks
SOURCE: right rear shock absorber detached from the top mounting point
Turns out that after 26 years and 233 thousand miles, the original strut gave up the ghost: Rust! I took the shock strut assembly out of a 'spare parts' Honda Accord I keep and replaced the broken one in the Honda I am now driving. Mechanically the car is still excellent, but the car is destined to dissolve around me! To remove the whole assembly required taking out one 14mm bolt at the bottom and three 12mm bolts at the top, some WD 40, several pieces of wood for leverage and a heavy mallet.. Since there is a heavy duty coil spring involved, one should take out the bottom bolt first and lift the bottom of the strut free from its position, ( this is where I used a long 2x4 and another piece of wood as the fulcrum point to pry the strut upward) Then undo the top 3 bolts and the whole unit falls out. You will also need to detach the brake fluid line that uses the strut itself as an anchor. The easiest way is to take the line off from the back of the brake drum housing ( 9mm nut) and remove the horseshoe clip and push the curved metal brake line through the small hole where the line is anchored to the strut. Use care as you will need to reattach the brake line again after installing the next shock strut. (Coil spring compression tool required) Needless to say, you will need to jack the car up and remove the rear tire first to access the whole thing.
SOURCE: how do you compress a shock absorber spring
You need a special tool to compress the spring and these are available from the auto shop. Make sure you get a good quality one and be very careful it doesn't slip because there is a lot of stored energy when the spring is compressed.
SOURCE: how do i replace shock absorbers on a 1995 mazda
ALLDATAdiy.com , all info , all mechanic shops are using it.
One car subscription for a year $26.95.
SOURCE: A6 front shock absorbers
Any vehicle that now incorporates strut suspension need spring compressors however be very careful which ones you use, the ones that have the two/three clamping arms are not recommended and can land you in the hospital when they slide off the spring as they always seem to do, rather use the big onne piece tool that encompasses the whole strut assembly into it and securley relieves the tension off the strut to be replaced.
Happy Motoring!!
