Or RTM read the manual for how to reset it. some work this way, pull power cord from wall push power button with NO AC power plugged in. then while holding power button , plug in the AC power to wall. this resets many, im not reading your manual for you. but you can.
You should get a new printer. There is most likely a bad piece of hardware where you are pressing options and its only a $119 printer. Its not worth throwing money at.
In the event that something turns out badly with your Dell printer, you attempt to fix it all alone or you take neighborhood arrangement which you regularly find expensive and not 100%. Along these lines, we prompt that you can get called "One Search Point" gave by us. We offer an immediate number that you can call and converse with the Dell agent on the telephone and talk about the issue with your Dell printer. Inside a moment, your concern will be fathomed and on the off chance that it requires further support, at that point you are given that also
Dell Printer Support Phone Number.
https://www.onesearchpoint.com/dell-printer-support-phone-number/
