I have a fresh air machine, had the error message "replace plate" which I did now when i turn it on and hit sanitize it works for a couple seconds and then flashed replace plate,I have replaced plate with 2 new plates but same result.
SOURCE: Fresh Air Maachine by Ecoquest
I've read from some other posts on here that Ecoquest is good about returning the items and replacing them.
SOURCE: I have a Fresh Air Unit from Ecoquest. The
Call toll free 1-877-710-0057 between 8: 00 AM and 5:00 PM Eastern time and they will gladly help you.
SOURCE: "Replace plate" messge appears. I replaced it but the message remains!
Regarding "Replace Card" warning, 90% of the time it's the female metal connector on the red wire going to the spring metal connection screws... The connector can have a buildup of corrosion ( green) build inside of the crimped connection. In that case, the crimped connector will need to be replaced. The black wire may also suffer from corrosion, but to a lessor extent. The replacement crimps need to be stainless steel crimps. The copper crimps corrode easily. Another thing to look out for are loose connections. The final solution would be to replace the card, or see your friendly dealer.
SOURCE: Getting an error message on
Hi, the error message says " replace RCI cell"
You have to order the RCI cells from the company or call this number (336) 326-7948. After ordering the cell, the instruction on how to replace it will come along with it.
More Info..
The RCI Cell must probably be replaced, this must be done about every three years.
The part costs about $90, parts available here.
Replacement is explain at page 15 in manual available here.
