SOURCE: how to clear M2 on minolta EP 4000/5000 cs/pro copier
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
SOURCE: m1 m2 m3
STO the value zero into whichever memory has something stored and M1, M2 or M3 will disappear
SOURCE: Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
SOURCE: minolta Ep4000 show CodeM2
Set the copier into Tech. Rep. mode by pressing the following keys in this order : utilty meter count stop 0 stop 1 then from the menu select counter then select Maintenance select the conter then enter anew value from the 10-Key pad
