SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
SOURCE: lg washer oe code pump pluged
open panel small door on left front panel. empty water and clear pump.
SOURCE: lg wm-2277hw front load washer getting a OE error
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: LG front load washer OE error. cleaned filter need
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!
