Invite a police officer to witness the loud music. There may be a noise ordinance in your town that can be used to stop the noise. At the same time, have the cop check for the pot odor and ask what can be done about it. You can also inform the apartment manager that smoking is going on. That might be enough for an eviction.
SOURCE: xbox stopped
Maybe not. Give this a try:
http://3redlightfix-xbox360repairguide.blogspot.com
and let me know how it works out.
SOURCE: my mother lives in an assistant living apt. on the
no worse than smoking a couple of cigarettes. she will be OK
SOURCE: Is there anything we can do to remove the smell of
I've adviced you to placed charcoal inside the unit overnight or when it is not in used.
Charcoal will absorb the upleasant odor from your microwave oven.
Thanks for using fixya...
SOURCE: Frigidaire Window/Wall Unit Dripping onto neighbor downstairs - suggestions for redirect?
Hello, you can use a drain hose and coonect it to the outlet of the drain hole. This way you can terminate the hose away from your neighbor.
Setting a thermostat has nothing to do with outdoor temperature, but more to do with what is a comfortable setting for you and your utility bill.
A common misconception associated with thermostats is that a furnace works harder than normal to warm the space back to a comfortable temperature after the thermostat has been set back, resulting in little or no savings. This misconception has been dispelled by years of research and numerous studies. The fuel required to reheat a building to a comfortable temperature is roughly equal to the fuel saved as the building drops to the lower temperature. You save fuel between the time that the temperature stabilizes at the lower level and the next time heat is needed. So, the longer your house remains at the lower temperature, the more energy you save.
Another misconception is that the higher you raise a thermostat, the more heat the furnace will put out, or that the house will warm up faster if the thermostat is raised higher. Furnaces put out the same amount of heat no matter how high the thermostat is set; the variable is how long it must stay on to reach the set temperature.
In the winter, significant savings can be obtained by manually or automatically reducing your thermostat's temperature setting for as little as four hours per day. These savings can be attributed to a building's heat loss in the winter, which depends greatly on the difference between the inside and outside temperatures. For example, if you set the temperature back on your thermostat for an entire night, your energy savings will be substantial. By turning your thermostat back 10 to 15 degrees for 8 hours, you can save about 5 to 15 percent a year on your heating bill -- a savings of as much as 1 percent for each degree if the setback period is eight hours long.
Hope this helps..........
