SOURCE: Kaz Honeywell Tower Air filter rest light
When the filter monitor light remains on, it is time to check/clean the IFD™ filters and reset the filter
monitor, if needed. With the unit powered on, insert the tip of a ball-point pen or paperclip next to the LED
filter check light and hold for approximately 5 seconds until the light turns off (Fig. 3). Depending upon
your individual usage (environment and hours used), you may need to check and clean the filters more or
less frequently. If the IFD™ filters are cleaned before the filter monitor light turns on, the filter monitor
should be reset at the same time.
SOURCE: troubleshoot honeywell hz311
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
SOURCE: I have a whole house
Hello, the most common reason this happens is because the solenoid valve is bad and remains open allowing water to flow continously regardless if the furnace is on or off. I assume you have either a sail switch or current sensing relay energizing the humidifier when the heat is on, if not thats another reason it would run continously.
