SOURCE: Pioneer model VSX-3300, I had
Do you have no signal on your radio..? KIndly find a better spot which could get better reception..
SOURCE: Pioneer VSX-4900S Receiver Connections
I know this is an old post but run front speaker outputs to the inputs on the sub then from the sub to the front speakers. bam!! it should work
SOURCE: lexus ls 400 air suspension stop working
If this light is flashing, there is a problem somewhere in your air suspension system. You can check to make sure its powered on in the trunk on the driver side. Behind the carpeting. This is a common issue with that particular year and model. The system tends to go bad righ around the 15 year old mark or so. Also if the light is flashing, the system is not working. Your just riding on the regular suspension.
Hope it helps
SOURCE: PIONEER VSX-9700S
Speakers must be selected on the front panel of the rcver, and tape ll monitor must be "off", or at least have an outboard processor attached to the tape ll loop. "A" or "B" doesn't matter, but one must be selected to hear program material. If all connections are correct and it still won't work, consider that the output stage has failed....accordianman
SOURCE: Pioneer vsx-819H: MCACC setup won't display on tv
Its because the pioneer does not display menu options through hdmi. You have to hook up basic yellow composite to monitor out.
