We laid the dishes on the counter before we poured the agar in, and we used a glass measurer to pour it in, and now my project failed because there is stuff growing in all 30 of them.
SOURCE: Kitchenaid Superba 42 Refrigerator Leak under Freezer when Water Used from Door
Either the water filter isn't seated properly or there is a crack in the tubing or the water line isn't seated properly in the coupling behind the grill at the freezer door. Also, inspect for breakage in the line in this area as well (coupling area).
SOURCE: Bubbles in measuring column
I had the same problem. How Frustrating. What I discovered is if you pour the water in really slow, the bubble do not appear.
This was one of 3 problems I had this this maker. The other two were.
I have been a Krups fan for many many years, dating back to the early 80s. After this even, I have become VERY disappointed with the quality of their consumer product line.
SOURCE: i have a adb2200awb amana dishwasher which leaving
Hard water is the reason for the spots. There is a new product out at www.dishwasherfilter.com that is made specifically to fix this problem. It filters the water going only into your dishwasher leaving your dishes spot free with every load. It is very affordable and guaranteed to work or your money back. You will love the way your dishes look after the very first load.
SOURCE: Tricity Bendix AW1400W front load. Water leaks
Ether the washer is over filling or has warn out the seals. If it has been abused (overloaded) it needs serious work. other wise the sensor may be stuck. Try 1/2 cup of vinegar with a load and see if that cleans the sensor travel area past the drum but inside the tub. This is a common problem for an old machine. Best leak is on the door and you may be able to tighten the screws but be careful it could mis aligne it so tighten a small amount and test by closeing the door. Do this at least twice before turning the screws hard.
