SOURCE: camera not working
Jackboy is onto it, I think if condensation is the problem. But I also think that cleaning of the contacts is a good idea too. You can do this with a pencil eraser quite easily.
Lastly, you could try resetting the camera. This is a fairly easy procedure which involves either going into your setup menu and choosing "reset," holding down the menu key for 5 seconds, or, removing the batteries for a few minutes. It may be that the firmware loading got corrupted and the camera just needs to be "rebooted," which is something that turning it on/off won't accomplish. But after which, you should have the camera reset to factory default settings.
Another tip is to go to the camera's website and look for firmware updates. Download and install them.
Lastly, digital cameras need alot of battery power. ALOT. batteries with a higher mAh - like around 2500mAh would satisfy the higher power requirements of your camera.
SOURCE: Can I use a memory card SD 2Gb in a camera Samsung Digimax S500 ?
Yes, you can use a 2 GB SD card in your camera.
THe SD card inside has a lever to its left Side .... Move it upwards ..... That is the lock on the Memory Card ...
SOURCE: samsung digimax s500/cyber530 won't start with new batteries
I have a samsung digital camera digimax cyber 530 - just replaced batteries and camera wont start, i get 3 flashes from the green light screen nw comes on then goes off & the lens wont retrack back in the camera
