Is there a user's manual available for the Royal Scriptor ii 69147t?
Hello, Sue - The Royal Typewriter Company now is known as Royal Consumer Information Products. I have not found typewriter manuals as an option on the Royal Consumer Information Products web page for Manuals: http://www.royalsupplies.com/support/drivers-and-manuals/ Nor have I found a PDF version of the manual you need online. Therefore, I suggest you contact the Customer Service department of the company directly (via a phone call) and ask about the availability of the manual you need. You will find the phone number on the web page cited above, in the lower left corner. Best wishes.
SOURCE: Electronic User Manual for HTC TyTN
Hi ,
I just saw the blog today. I assume you might have found the manual by now. In case you haven't, you can download the manual at:
http://tech-faq.phonedog.com/cell-phone-research/htc-tytn.aspx
SOURCE: Royal Portable typewriter ribbon
Hi, I have a Royal Companion Portable from 1940's. I bought new ribbons at mytypewriter.com (select the "Royal Portable" ribbon). It fits. Anyway if it doesn't it's not an expensive mistake, but I researched this and apparently all vintage Royal Portables have the same standard ribbon. Worked out in my case. Good luck!
SOURCE: AX-90 NAKAJIMA TYPEWRITER USER MANUAL NEEDED
Contact Nikajima @ 1-800-809-7138 they are very helpful.
DickyO
SOURCE: Need help releasing margins on an electronic typewriter.
Did you hit the MAR and REL buttons at the same time?
