SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
SOURCE: my LG split system Model
It's communication error between indoor and out door. Make sure you have command from indoor by checking volts in out put of indoor or in put of out door. If not, Check your PCB and also loose connections.
SOURCE: Mini Splits flashing "ch" then
CH61 means Condenser coil temp high due to non cleaning of condenser/over charged gas/non condensable gas.
Clean your condenser coil. If still problem rests, due to non condensable gas also there will be high temp. Once remove the gas, flush out the system and vacumize and then do gas charging.
This is a warranty issue. Go back to whoever installed it.
