Heating & Cooling Logo
bryan lee Posted on Jan 23, 2019
How do i changa my wall direct vent heater from gas to propane.what does this in tail
5 Related Answers
A
Anonymous
  • Posted on Aug 30, 2007
SOURCE: Empire Wall Heater(propane) won't stay lit
John Mac here...the solution was that we had shut the pilot off for the summer, and birds had made a nest inside the heat exchanger...coming in through the direct vent. Cleaned out the nest, and it works perfectly. My technician recommends that I leave the pilot buring through the summer to prevent this in the future.
Anonymous
  • 1420 Answers
  • Posted on Oct 16, 2007
SOURCE: physical difference between natural & propane orfice
Merry Lynn, there will be no physical differences between Natural Gas heaters and Propane Gas heaters. Check the model number of the unit, it may have a N or P or LP printed at the end of it to distinguish which gas it uses. The plate that is attached to the heater should indicate the type of gas it uses.
DO NOT try to convert this heater to another gas.
Anonymous
  • 1420 Answers
  • Posted on Sep 19, 2008
SOURCE: B vent configuration of direct vent propane heaters
Yes, the design of the combustion chamber is limited at how much fresh air and combustion air can enter it. If you lengthen the venting, you will be causing more restriction and there will not be enough natural air movement to make it work. It will start, run for a minute or two and poof out. Not to mention you will be circumventing it's UL rating and if you sell your home with it installed, you are liable for any fatality or damage. Do you want to risk that? Don't even think of doing it! There are "Box" heaters out there sized from about 5,000 Btu's on up to 100,000 Btu's. Check the web.
Anonymous
  • 188 Answers
  • Posted on Jun 30, 2009
SOURCE: propane heater has spark but wont light
ODS/Pilot may be clogged make sure you clean it out according to the instructions in your owner's manual. If you need a copy of the manual let me know and I will try to find it for you. If it is still not working it could be the gas regulator or the ignitor cable. For Glow warm parts contact Master Parts at 800-446-1446 or you also can find them online at www.masterparts.net. I hope this helps you!
Anonymous
  • 1214 Answers
  • Posted on Dec 10, 2009
SOURCE: Wires not connected to gas valve need wiring
I think you mean a milli-volt system. I went to the cozy heaters website and found the wiring diagram in an owners manual for a similar unit, a W355. I bet the wiring diagram will work for your.
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Problem is with my Rinnai propane gas heater in my LIVING ROOM, not car. Please see previous question. Thanks.
Turn it off. Check connections and hoses with very soapy water for leaks (it will bubble)
If you can't find it... I would either return it if possible... or go take it to a propane professional for testing.
I need a thermocouple for a dyna glo natural gas wall heater
Billy here's a link to A & B Sales. They have what you're looking for. Whether your heater is Natural Gas or Propane makes no difference when it comes to thermocouples.However the length of the tubing does when it's a wall or stand type vent-free heater.
http://www.aandbsales.com/2.html
Hope this helps you & thanks for choosing FixYa.
How to change gas orfice to propane glass smokes up. soot
Is this unit originally set up for natural gas? If so, the burner oriface and the gas valve need to be retro-fitted to propane. This is something only a qualified service technician should attempt as an incorrect retro-fit could cause an explosion resulting in someone getting hurt or even killed.
How to change the orfis from propane to gas on a empire 40,000btu
what is the model # for the furnace. You are going to have to change the pilot orofice and gas valve for natural gas also.
I just bought a used Rinnai 1004f propane monitor and it came without the vent to outside. How can I get a vent? (Maybe kit) The wall is 16 inches thick. Jim Marstaller Naples, Maine
is this a vented or non vented unit? have you checked the rinnai distributorship? call Adirondack Hardware in Keeseville NY. They have parts for Toyostove, Monitors and Rinnai heaters. Their staff are very well versed in all kero and propane heaters.
Light soot around propane fireplace vent
burners burning yellow , in complete combustion , blocked air ways to burner , it needs a service soon as poss
2answers
You have a crack in your heat exchanger and it is sucking in products of combustion. Replace the heater. OR there is a blockage in the intake or exhaust vent. GET IT FIXED OR REPLACED!
Top Heating & Cooling Experts
Paul Carew
john h
