This is only a guess as I'm not familiar with that model, but it sounds like a sensor is telling the dryer it's dirty.
You may have to do a through cleaning of all the ducting and traps and ensure that the sensor is working properly and isn't clogged/plugged/stuck in the error position. Sorry I couldn't be much more help. Good luck!
SOURCE: Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
SOURCE: Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
SOURCE: my kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
SOURCE: washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
