SOURCE: HOTPOINT FRIDGEFREEZER
i i you will need to replace your defrost sensor and thermal fuse
this is how to do the repair and not have to defrost and leave doors open for 48hrs time after time
SOURCE: AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
SOURCE: the fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Did you ever get this resolved? I’m having the same issue with a Miele freezer
