SOURCE: reset timer after battery change in seiko sna285
If the stop watch hands are not in the "0" (12 o clock) Position, follow the prodedure below to set them to the 12 o Clock position
1, Pull the crown to secound position
2, Press Button "A" for 2 seconds.
3, Press Button "B" to Adjust the minute Hand to "0" Position
4, Press Button "A" for 2 secounds then press Button "B" to adjust secound hand to "0" Position
5, Press crown into normal position
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
SOURCE: watch hour and minute hands are not lined up at 12 o'clock
Take the back off, then slip the works out of the case. move the hands to line up at 12.. hope this helps..
SOURCE: Watch setting instructions SEIKO 7N43 8A39 "A1"
If you are still wondering about this, pull the knob out to the first click. turn one way to set day, turn the other way to set date. Pull out further to set time.
SOURCE: I have an old Seiko model #seiko clock ref ej 105G
Thank you for contacting FixYa. I highly recommend that you send to Seiko and I found you the perfect link with all this info. http://www.seikoclocks.com/#FAQ Best regards!! Jewel
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
Good luck and thanks for using fixya.
