If light is ON with door closed, the door switch is not functioning, it will not run as it believes the door is open.
Make sure door is closing properly.
Could be improper voltage, door switch, start switch, thermal fuse, broken belt, timer / control, wiring, or motor
Always check the breakers in your electrical breaker box in house first. I say this because it takes 2 for dryers one for coils and lights the other for motor and thermostats. Next check door switch by listening for contact click sound when you push the door closed if you hear it switch is good and most likely motor is bad.
SOURCE: only part of dryer that comes on is the inside light.
Replace:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
