It can be fairly difficult to open the cabinet of a bread maker, especially if the parts all fit together snugly. The easiest way to do this will be to start by removing the screws that hold the cabinet together. You may need to use a screwdriver to remove the screws, depending on how they are secured. Once all the screws are removed, you can then carefully pry apart the cabinet to access the drive disk and belt.
SOURCE: West Bend Break Machine Model 41086 Parts
Do you have the manual for the 41086? I am in need of it.
SOURCE: West Bend bread maker -stems turn paddles are loss
check your manual.
If you don´t have one, check here:
http://manualfox.com/link/westbend.htm
They can get you any West Bend manual. Just send them a request.
SOURCE: need manual for West Bend #41088 Bread machine
Here is a link for a user manual for your bread machine. The manual is in a PDF format which means you need Adobe Reader to open it. If you don't have it on your computer you can obtain a free copy by going to the link below. Best wishes.
User manual:
http://www.focuselectrics.com/supportdata/L5088_Automatic_Bread_Dough%20%20R.pdf
Adobe Reader:
http://www.adobe.com/products/acrobatpro/tryout.html?sdid=EGBRB
SOURCE: West Bend America's Best Bread Maker 41030
Download Free West Bend Manual At:
www.focuselectronics.com
Click "Instruction Manual" Tab at Top of Page
click on Breadmakers
Click Model (stamped into metal bottom or on back of unit)
Also Suggest "Supplemental Recipe Book" (Last item on that list)
