Televison & Video Logo
P
Pamela Posted on Jan 23, 2019
How to get Adobe flash so I can watch Comcast TV programming
Khurshid alam shohag
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jan 23, 2019
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
19594
Points
37
Google play store
1 Related Answer
Anonymous
  • 137 Answers
  • Posted on Apr 15, 2009
SOURCE: I can't watch any video movies
To view video you should install the Flash Player plug in.
You have to install this manually.
First go to the flash player site
And download the set up file(Save it to any location)
Now close all FireFox windows and run the Flash Player(Set up file)
Now you can view video
Cheers!!!...
Programing my xfinity remote
About 13,200 results (0.79 seconds) Search Results
    Can't program Comcast remote to Element TV - Comcast Help and ...
    forums.xfinity.com/.../XfinityTV...program-Comcast-remote...Element-T...
    Jun 6, 2011 - I have an Element 47" Class LCD 1080p 60Hz HDTV, ELGFT471. My remote is the Comcast Universal Remote - Red OK/Select Button.
    Comcast - what programing code to use with element tv find ...
    https://www.directly.com/.../comcast-what-programing-code-to-use-with-...
    what programing code to use with element tv find a code does not work ... Mymistake. ... Also found that Element has a remote update for some televisions.Missing: panel
    Element Tv Comcast Remote (Tut) - YouTube
    ? 3:19
    https://www.youtube.com/watch?v=ZDBr-hZN2AI
    Jan 20, 2010 - Uploaded by TopBreakX3
    The tut should be in your comcast remote paper help thing but heres the code if u cant see ... cant see clearly ( 10178 ) This is a vid on how to setup your comcast remote for your element lcd tv. ... Who cares program the Comcast remote already ... this was awesome,,,,my sisters tv is on the go now,,,thanx .Missing: panel
    Comcast Remote Codes for TV - Easy PC Tutorials
    www.easypctutorials.com > Comcast
2answers
Code for programming to a LG 4K tv?
  1. LG UHD 4K Television - LG.comā€Ž
    Adwww.lg.com/UltraHD4KTVā€ŽRatings:Reliability 9.5/10 - Picture quality 9.5/10 - Features 9.5/10
Search Results
    Find Your Comcast Remote Control Programming Code
    customer.xfinity.com/...tv/finding-your-remote-control-programming-co...
    Learn Comcast remote codes and more information on how to program your remote control. ... To Watch On Demand Programming with XFINITY TV:.
    DIRECTV - Remote Control Code Lookup
1helpful
MITSUBISHI VS-60705 Comcast related. Power went off, TV was not showing comcast anymore, I tried installing Channel Plus + and now cannot abort the message. The message has been on TV for 3 days already....
Check with comcast but have you tried to remove power from all units involved here for a while, then power back to see if the reboot will help or not.
Everytime I want to listen to music or watch a video it tells me that my adobe flash player has crashed
Close all web-browser windows (Internet Explorer and Firefox).
Click Start
Click Control Panel
Click Classic View
Click Add/Remove Programs
Click to select Adobe Flash Player.
Click to uninstall.
Close Add/Remove Programs.
Close Control Panel.
Access: http://www.adobe.com/software/flash/about
and allow it to install the most-current version of Flash Player.
Try again to watch a video.
I need to program my cable box
The real problem with the Comcast remote is that there is no other brand, it's not like a Sony remote that's relabeled or anything. Fortunately, Google helps again, and it turns out Comcast has a page online about programming the Comcast remote control.
comcast_remote.jpgComcast 3-in-1 remote control To program the remote to work with your Sony TV, you need to take the following steps:
  1. Find the code or codes for your TV from Comcast's list [PDF]
  2. Turn your TV on
  3. On the remote, press and release the TV key on the very top of the remote.
  4. Press and hold the Setup key, until the "TV" key flashes twice, then release the "Setup" key.
  5. Using the number pad, enter in the first 4-digit code found next to your television brand on the chart. If you do this correctly the "TV" key will flash twice. Now it's programmed!
  6. Now point the remote at your TV and press the Power key. If the TV turns off, you're golden. If not, try again with the next code on the list.
Programming comcast remote
the codes for the remote to access a Proscan TV are as follows: 11447, 10047, or 11347. I assume you know how to get into the remotes coding mode, but if you don't Here is how you go about it press setup, then press and hold the TV button until the light flashes then input one of the code sets, then if you get a confirming flash hit the power button if the TV turns off your golden if it didn't repeat the cycle with the next set of numbers I gave you. if after you have tried all three numbers you still can't get the TV to react to the remote you will need to call 1-800-COMCAST and speak to someone on their technical staff.
2answers
I have a haier tv with a comcast remote. Need the Haier code for the comcast remote
10768
  1. Turn on your device (i.e. TV).
  2. PRESS the button for the device you want to program (TV, VCR, CABLE, AUD, etc.) then RELEASE.
  3. PRESS and HOLD the SETUP button until the red LED for the selected device flashes twice, then RELEASE.
  4. ENTER the 5 digit code for your brand from the list above.
  5. You should receive 2 quick flashes on the LED for the selected device after entering your code.
  6. PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
ILO TV
push the "Pic Size" button and make sure it is not on Panoramic, that setting stretches and warps the right and left side of the picture
80helpful
6answers
Top Comcast Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
Are you a Comcast Televison and Video Expert? Answer questions, earn points and help others
