SOURCE: Miele WT 945 Washer Dryer - Spin not working + Water Inlet/Drain Light Flashes
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Your filter of the water inlet valve is accessible outside the machine; it is at the water entry point. Close your faucet & check this out; this gets clogged often.
Hope i am helpful...... Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
SOURCE: Unable to loosen and unscrew kitchen faucet screen...
If you have a lime problem, try soaking the tip in boiling water with vineger added to it. The acetic acid in the vineger disolves the lime. I did it just last week when I serviced my kitchen faucet. It may take quite a while for the lime to disolve, but in the end you will achieve your goal.
SOURCE: 94 jeep cherokee 4ltr. Leak at oil filter adapter
It is very hard to turn, but it will come loose, a cut off allen wrench attached to a pipe works great, as there is no clearance to do it any other way. Have at it cause the allen bolt is pretty hefty.
SOURCE: parts for a honda lawnmower hrx 537
It would depend upon WHERE in the world you are located but you should be able to contact your nearest Honda Mower dealer or do an internet search for
>> "hrx 537 honda parts" << and it will return quite a few places both on-line and in-person place where you may purchase them
