Re: The Cummins power generator fault shut down 1448
This indicates a possible fuel problem or overload condition causing an under-frequency shutdown. Cummins gensets are very particular about gaseous fuel delivery. Check the specs and make sure the fuel supply line is of adequate size for its length.
Please ask your supplier who supply Cummins generator to you. They should know.
Different generator, the answer will be different. Your supplier can help you.
More Cummins diesel generator, please visit www.dieselgeneratortech.com
Odds are that the ignition switch or wires are giving you the grief.
Thee unit will probably be getting spark power through the starter solenoid (look for a wire there) but when the solenoid is not activated, there will be no ignition power.
Take your time and trace it down.
You'll get it.
Cheerfuls!
If this unit dies under load conditions, decrease your load and try it again.
If this happens under no-load conditions, check your fuel supply. Start with the filters, then check pressure and flow.
