SOURCE: Hunter Thermostat fan won't turn off
Hi and welcome to FixYa,
Initially, I am inclined to suspect 3 possibilities:
Good luck and Thank you for using FixYa.
SOURCE: Heat pump is humming loud>
When the heat is not on. Go to the T-stat and turn the fan to the on position. With the blower now running is it making the noise? If so you probably either have something in there such as the filter that was mentioned, a piece of paper etc. or one or more of the blades on the blower wheel is vibrating. Don't let the condition persist w/o having it checked out or you may turn a simple fix into a costly one.
SOURCE: our controle module TH132 A/F/AF goes blank every
I have also had the same problem with 2 units. I have been in touch with Aube who say they have identfied a problem with the back unit which they will have fixed in " a few months time". My suggestion would be to contact them for a replacement later on this year
SOURCE: our TH132-AF keeps going blank and shutting down
Robbo,
I've had the same problem and it's due to the unit breaking down due to a 'snubber' not being fitted to the contactor (across the coil). It's a small resistor/capacitor that smooths the switching load coming from the stat. Without it, the trickle feed coming from the stat makes the contactor's coil bounce and damages the stat. Tracking one down, however, is proving to be a problem, as no-one seems to have them in stock. I have found one now, though from elementshop.co.uk here:
http://www.elementshop.co.uk/product.php?pid=1022&cat=251&nm=
SOURCE: 2004 Range rover hse warning light saying
Bring the car in, I just replaced a transmission last month in an 03
