Go to
http://torrent-finder.com/open/36-Fulldls.com/%20update%20drivers%20
and use torrent to download the program
Use it to update any driver
Enjoy
[email protected]
SOURCE: Cricut Expression flashing lights
Souns to me like the cutting slide head is binding or the material transprt has a meesed up gear train. Or the case has been fractured
SOURCE: my cricut will turn on but the lcd screen is black
Sounds like you have a bad connection in there. I would contact Cricut for tech support; they will probably be able to send you another machine to replace yours. Mind you they will put a charge on your card and remove it when they receive your machine. I hope this helps if you need their contact number get back in touch with me.
SOURCE: My Cricut Expression keeps turning on and off.
I have one of these machines stripped down on the bench now with this problem. I have located the fault to a power relay which is sealed but must have burnt contacts as it is not passing the power to the machine to power up. I am still looking for a source of 18 volt coil relays with 10 amp contacts to fix this one. If not I may have to modify the circuit to overcome this problem.
SOURCE: My LCD on my cricut
after doing some research i found a lot of problems with the machines purchased this xmas exp the colored ones the best thing is to contact cricuit and see if they will replace them
