SOURCE: LOOKING FOR REPLACEMENT ELECTRIC CORD
Please check the lin below and see if the spares you require is available. If not post a query to the suport link.
http://www.espares.co.uk/search/microwaves/p/1095
SOURCE: I have a Big Boss
i was having the same issue with my grill it wouldn't turn on; i found the problem to fix it. There's a fuse on the bottom plate its the red wire with a sleeve on it screwed to the plate. take the screw off and pull the sleeve back and you'll see the little fuse, you can bypass it with a little wire going before the fuse to after the fuse but being on the safe side just replace the little fuse! and that's all there's to it.
SOURCE: canI purchase flat grills to replace the grills for useing to make sandwiches?
if they are made you can but it will cost less to get a sandwich grill Welcome to George Foreman Cooking Shop Indoor Electric Grills and Grill...
