Try to charge it in different plug ins and try to hold the to turn it on myiTouch Curve Unisex Smart Watch
SOURCE: LG KG800 charging problem.
if you already change the battery;' theres no problem with the battery; i think the problem is software try to reset the factory setting if dosen't work/ reinstall software
SOURCE: Curve says it's charging, won't turn on!
I would recommend that you remove the battery for like 10mn and insert it back in the device..it should solve the problem you are having..
SOURCE: I just replaced my H320 iRiver battery last night.
Probably you installed wrong. Depending on the battery manufacturer, the end contacts must be swithced in order for the battery to work. Read about it in the Misticriver forums. Good luck!
SOURCE: blackberry isn't turning on
Try this method it works
When your device fails to start, it show one of these symptoms:
1. Totally dead.
2. Trying to restart, LED activity only.
3. Failed to start, a white screen with an error message.
__________________________________________________ ________
1. Physical damage, water is the worst enemy of delicate electronic
device. Try drying it with a desiccant and replacing the battery. If
there is no activity, you can still try the last ditch technique,
nothing to loose anyway.
2. Your device is not able to start, something has gone wrong and the OS is corrupt.
3. Geeks call this an "Uncaught exception error". That is a polite way
of saying, the last thread has terminated, the OS has halted because it
is corrupt.
In many cases, the Application Loader can be used from Desktop Manager or Windows,
If that fails to connect, there is one final solution. Go Old Skool ...
The good news, starting from scratch, you will be back in service in a couple of hours.
2. You need to install a BlackBerry OS file that is specific to your
device. The original version, as supplied by the carrier, is the safe
choice, but you can use any model specific version.
3. Once the OS has been installed, you have to prepare it for the device.
Select Start / Computer and select the Drive C: Icon.
Open Program Files / Common Files / Research in Motion / AppLoader.
Navigate to the bottom and delete the file Vendor.XML file.
4. You are now ready to restore your device. Verify that BlackBerry Desktop Manager is NOT running. Plug the device directly into the computer's USB port.
SOURCE: no power
Try to remove your battery and plug in your AC adapter
If its working:
You need to replace your battery
If its not working:
Try to check if the LED indicator is lit
If the LED indicator is not lighted. Replace your AC adapter
Thanks. Cheers!
