SOURCE: trying to ventilate and hot water not flushing through on button 26
Before you press water button to vent you need to restore to factory settings.
First press menu (far right button) then toggle to restore factory settings (using far left button), press menu button then far right again until yes comes up, then press menu button. Press esc button (3rd from left), machine should now be back to normal. Then press water button (3rd from right) and turn steam knob to vent until free water is coming through.
This is the only way I could get mine to work!
SOURCE: hot water coming out of overflow pipe on my vulcan everhot water
Assuming you are talking about the temperatur/pressure relief valve, it is stuck open.
1. Turn off gas or electric to water heater
2. Close water supply to water heater
3. open hot water faucet on nearest fixture to depressurize hot water system.
4. close tpr valve (you may have to push in on the center spine. It may be resistant to closing from sediment. If so, opening and closing several times may solve that issue.
Once you get the tpr valve closed, close the faucet and open the supply valve. If the tpr stays closed, go ahead and turn on the gas/electric and re-light pilot and turn on control etc.
If the TPR blows again, you will need to replace it. YOu can buy a new one at any plumbing supply store. Shut down the heater again, drain a bit of water out using the valve on the bottom of the tank. there is probably copper pipe connected to the TPR valve which you may have to cut or maybe can just unscrew. The TPR threads out of the tank, install the new valve (make sure to use pipe dope or teflon tape.
SOURCE: Very Hot water coming out of overflow pipe
Is your boiler heating your domestic hot water if so i would turn water off to water maker and see if your boiler pressure stays down below 20 psi. If so water maker is bad. The other thing that could cause this problem would be the boiler pump is out.
SOURCE: descaled machine, clean solenoid valve. now steam is coming
try replaced gasket in high pressure valve.
Testimonial: "this person is soooo helpful. It has been amazing to learn."
SOURCE: Pasquini Livia 90 - No water from the group head
The problem could be calcium built up blocking the jet and stopping the flow of water through your 3 way solenoid valve.
Otherwise the 3 way solenoid has stopped working. The 3 way valve part #91004 is $105 + shipping.
If you capable of removing the top and 3 body side of the machine, you can contact me and I can walk you through diagnosing if this is the problem with the jet or the valve. Before you call, make sure you have a philips screwdriver, 14 and 15mm open ended wrench or crescent wrench, flashlight, and paper clip.
My experience is working over 10 years at Pasquini as a master technician
running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso
machines and grinders. Contact us for any of your Pasquini sales and
service needs.
