My Kenmore Elite oven with ES 585 Electronic control would not heat up to the desired temperature. I could hear the relay click on and off wanting to heat (which applies voltage to heating elements). I accessed the control circuit board and found cold/bad solder joint on the relay connections. I re-soldered the connections and the oven works great!!
Element could be bad or temperature sensor / probe.
SOURCE: kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
SOURCE: Oven doesn't reach temperature
Page 6 of the owner's manual:
Adjust the temperature calibration.
SOURCE: MY GAS OVEN TOOK 2 HOURS TO REACH THE DESIRED TEMPERATURE OF 350.
the ignitor is prolly bad (not pulling enough amps)
SOURCE: Temperature Control
we have a similar problem with an AFG 7080 model, with inability to control the temperature
how and where do we find the condensor and how do we get hold of the right manual?
SOURCE: The oven will not reach desired temperature. Had
it sounds like you have a bad temperature controller thermostat or your temperature sensor inside the oven, (a metal rod attached to a thin metal wire) is not in its proper place. It clips into connectors located at the back center of the oven itself.
