Removing the plate ejector from the Eco+Chef ceramic nonstick electric skillet might require some disassembly and should be done carefully. Please note that disassembling the appliance might void the warranty, so if the skillet is still under warranty, consider contacting the manufacturer or referring to the user manual for guidance.
Here are general steps you might follow to remove the plate ejector from an electric skillet. Please keep in mind that these steps can vary based on the specific model and design of your skillet, so it's crucial to consult the user manual or the manufacturer's customer support for precise instructions.
Remember, if you're uncomfortable or unsure about disassembling your electric skillet, it's best to seek help from a professional technician or contact the manufacturer's customer support for guidance. Attempting to disassemble the appliance without proper knowledge might lead to damage or injury.
SOURCE: broken ceramic insulator
This is techcrazy
You have not provided with your place of residence. considering you to be stationed at USA i provide u with the following address
Po box 718 15940 minnesota avenue
paramount california usa 90723
email:[email protected]
tel no: 562-633-2045
kindly rate me on the above said solution
SOURCE: one of the burners won't light.
check all wires to burner and switch. If they are good .....burner burnt out or switch no good.
SOURCE: Non-stick skillet
you can goto rivalproducts.com
they still ahve that model available
for less than 60 dollars
SOURCE: Where can I find a electric skillet cord for model GE electric skillet model 168948
I found one that has lasted me for 2 years, for $5.00 at Goodwill!
SOURCE: ceramic insulator on a faberware electric skillet
Seems they sell these at partStore.com (run by Best Buy)
http://www.partstore.com/Part/Applica/Farberware/FSS330A/Applica/Farberware/22463/New.aspx
