I've identified the error code as F10 and now I'm interested in a method to overcome it, if possible. Thanks!
SOURCE: Ariston Washing machine A1636 - Flashing lights
always reset your machine ;turn your dial to the end of the cycle [ the dot] it should flash 3 times quickly, then turn off the machine and on again. then start washing again ...hopefully..worth a try.
SOURCE: ariston washing machine error message
PUMP WASH BLOCKED WITH A SMALL PIECE OF CLOTHING UNBLOCKED AND MACHINE WORKS FINE
SOURCE: hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
SOURCE: error code 43 on F& P washing machine
The micro switch or the lever that activates it seems to have been the cause of the Error Code 43. Have re-seated the switch in its holder and ensured the activating (out of balance) lever is moving freely. The switch appears to be OK and now it is all re-assembled, the Error Code 43 is gone. Machine is operating normally again.
Out of Balance Switch was located below the right hand side of the computer board (module).
Rgdz John T
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
