It is a known issue and also common, so common the maker mentions it!
If your coffee maker is leaking water, then the most common cause is the water reservoir's overfilling. Ninja coffee maker comes with a marked line on the water reservoir that indicates the water level the reservoir should hold.
Jul. 21, 2020
reservoirs are just that reservoirs. Once the radiator has been filled to the radiator cap and the cap is operational the heated expanded water will flow out to the reservoir . When the engine cools down the resultant low pressure in the radiator sucks open a valve in the radiator cap and sucks water back into the radiator the . If you have to always fill the radiator and it is blowing water out into the reservoir but not sucking it back then I would have the cap tested for operation or check for a leak in the cooling system or hose from the radiator to the reservoir.
If you pour water into the machine, and water comes out, then the reservoir is full of water. There is no way the water can bypass the reservoir and go directly into the pot.
The reservoir of your iron needs cleaning if it looks as though small deposits are being left in the small holes on the soleplate. Typically, the deposits are minerals from the water that you are using in the reservoir. The deposits may have a white color, and they may resemble salt.
Cleaning the reservoir requires the use of white vinegar and a clean rag. Fill the reservoir of a cold iron at least one fourth of the way with white vinegar. Turn the iron on and place it on the steam setting. Steam iron the clean rag until the reservoir is completely empty.
If the deposits are still visible to you, you will need to fill the reservoir with clean water and steam iron a rag again. If the deposits are still visible to you after this, you will need to repeat the process with vinegar until the deposits are no longer apparent.
Rinse the reservoir thoroughly with clean water by filling it completely and then emptying it completely. In order to avoid mineral buildup and deposits, use only distilled or purified water in the reservoir. If you continue to use tap water, simply remember to clean the reservoir periodically.
Vinegar has a strong smell associated with it, especially when it is heated. Ventilate the area where you are working as much as possible, by opening windows, turning on vents or fans, or keeping the door open.
The water you use to fill your iron is causing this problem. Once you clean it use distilled water available by the gallon at the grocery store. Joe
Problem was a stuck float in the small water reservoir to the rear left of the unit.. Remove top and left hand side panel. Small reservoir can be seen at the bottom left. Remove small screw and slide off the cable assembly above. You should then see into the reservoir and the float. Clean float and reservoir and reassemble.
Empty the water reservoir and put back on the side of the Kurig. Put your hand in the reservoir and slide the disc that monitors the water level back toward the top and and hold in that position,the machine will think there is water. Then put a cup under the head and select a cup. The water will come out. You must hold the disc up inside the reservoir to continue to get the water out.
FOR HOUSEHOLD USE ONLY
FILLING INSTRUCTIONS
1. Place the unit on a stable surface.
2. While holding the water tank with one
hand, move the release lever toward the
power cord.
3. With the reservoir released, pull up on
the reservoir to remove it from the body of
the unit.
4. Turn the reservoir over, revealing the rubber
inlet cover.
5. Open the inlet cover and fill the tank
with everyday tap water (filtered water may
reduce hard water problems).
6. Close the inlet cover and return the
reservoir to its place, making sure that the
reservoir is secure.
I'm willing to try this to clean the mold out of the steamer container and possibly the rest of the attachments:
1. Empty the water reservoir completely.
2. Place 20 mL of CLR or bleach into the reservoir.
3. Fill the reservoir with hot water.
4. Shake the reservoir to mix and let stand for about 1 hour.
5. Empty the reservoir completely.
6. Rinse the reservoir 3 or 4 times with cold water.
7. Fill the reservoir with distilled water.
8. Run the steamer into the ventilated air a couple of times to ensure that there is no CLR or bleach residue on the evaporation elements. Thus, there will be no bleach on your cloths.
I have the same problem and will try this out tomorrow. I will tell you how it turns out.
My husband found in ours that the little float was stuck over the sensor (the little patch) down in the reservoir. The float could not rise with the water, thus, the machine did not know that there was enough water available and it would not stop blinking. He took the dry reservoir out, turned it upside down and shook it! This worked for him, as it unstuck the float. He said that if that doesn't work, the thing is really stuck and you might as well return it.
