These are best john deer forum they will have fixes ect
http://www.mytractorforum.com/12-john-deere-forum/
http://www.tractorbynet.com/forums/john-deere/
SOURCE: I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
SOURCE: John Deere Three Bottom Rollover Plow
Hey, the "round cylinder" is a power steering motor for a John Deere 630. If you start looking for one of those instead, I'll bet you'll have better luck. Deere dealerships tend to not care unless you're buying a half million dollars in equipment.
SOURCE: 3350 on cold start hydraulics ok then after a
Does the pump make any noises, if you touch the cylinders are they hot ?
SOURCE: 4020 john deere compact diesel. Lost hydraulics
I doubt that it is the fluid level...it's been a few years... but I seem to remember there being a couple at the front of the motor that ran the hydralic pump...I am wondering if your problem is not there...tthe hydralic pump sits under the fuel tank at the front of the tractor... check there to see if everything is working right there...of course it could be the pump its self that has gone bad...
heatman101
SOURCE: JD 4020 Row Crop Tractor; No power Steering, No
In regard to the problem - JD 4020 Row Crop Tractor; No power Steering
What was the problem and how did you fix it I'm having a simlar problem
