Won't let water in
Hello.
The Hotpoint is a portable dishwasher that has pump guard, overflow protector,rack bumper to prevent the rack from falling out of the dishwasher duringmovement, and temperature and wash options. When the dishwasher is properlyconnected to a water and power supply, it should work well in general. However,if something goes wrong, such as if the dishwasher will not fill with water,some troubleshooting methods may be beneficial in finding a solution to theproblem.
Instructions.
1 Ensure the water faucet is turned on and the connection between the water andthe dishwasher is secure. The hose connector should be snapped into placebetween the water faucet and the water hose.
2 Straighten the water hose and check for possible obstructions in the waterhose, the water faucet and the hose connector. Clean as necessary. Turn on thefaucet hot water slowly until it is all the way on to ensure proper water flowto the dishwasher.
3 Open and close the dishwasher door firmly. The dishwasher will not start awash cycle if the door is ajar. Verify that the dishwasher is plugged in to aworking power supply and that a wash cycle has been selected.
4 Avoid running other appliances that use water, such as a clothes washer,while the dishwasher is running, to avoid improper water pressure. This mayresult in a lack of water flow to the dishwasher.
5 Check to make sure large dishes, such as cookie sheets, pots or pans, are notblocking the spray jets. Avoid overloading the dishwasher.
Thanks.
