Hello. My watersnake T18 trolling motor stopped working and I have no idea how to fix it. It's not the battery nor the leads but that's all I know. Any hints of what is wrong and how I can fix it please
Most likely cause of failure is water got into the motor.
I have a Watersnake T24 motor that would not work after one year. I checked the switches and found that the forward-off- backward switch was defective. Sometimes the sudden increase in current could melt the inside components in that switch which I discovered after opening it. My T24 uses a 30 amp switch and it was very difficult to find that replacement switch in Canada. I eventually found one in AliExpress with a 30 amp rating. It takes about 2 months to have it shipped here from China. With the T18 model you should be able to find one easily with a 20 amp rating.
Https://www.manualslib.com/manual/1549878/Watersnake-Saltwater-Asp-T-18.html trouble shooting guide and also customer service
This is a brand only available in Australia. As Ray says, you need to find where the water got in.
Watersnake T18-S Transom Mount Electric Motor ' BCF
https://www.bcf.com.au > watersnake-t18-s-transom-mo...
Mar. 9, 2021 - Buy the Watersnake T18-S Transom Mount Electric Motor online - BCF is Australias leading outdoor clothing, footwear and gear retailer with a ...
SOURCE: Minn Kota Model 35 24lb thrust transom trolling motor not getting power
I have a Minn Kota Model 35 24lb thrust transom trolling... I am not getting power to the unit, I tried taking the top plate off & bouncing power past the four position switch and still no movement of the prop. With that in mind,,,,,I belive I'm looking for a new swiotch controll, anyone have one for sale???
SOURCE: Hook up for one battery operation for minn kota trolling motor
I am not sure which trolling motor you have but click the link and scroll down to select your trolling motor the battery hookup is the last page
http://www.northlandmarine.com/MinnKotaQuickRef.htm
SOURCE: new MotorGuide VariMAX trolling motor does not run
The motor should work without the circuit breaker for a test. The breaker is a safety device to protect the motor and wires if something malfunctions.
SOURCE: Trolling motor doens't work
I have a trolling motor and can't seem to get it to come on. I seen it work when I got the boat. But now it won't come on.
SOURCE: we have boat that came with trolling motor, boat
My guess is the motor has leaked water into the lower motor assy (behind the prop). and needs to be cleaned up and the brushes replaced.
here's a schematic:
Edge 40
You can try this to check for water leakage:-
1) disconnect from power supply
2) remove the prop
3) you will see 2 bolt heads behind where the prop was. Remove ONLY ONE of them for now.
4) if you see the bolt (it's about 8" long) is covered in what looks to be blask, oily/watery or rusty condition then you know that you'll need to overhaul it.
5) if it IS the motor assy, remove the other bolt and disassemble everything noting their location.
6) I would recommend replacing the brushes Part# 188-052 and the seal kit 2883460.
