My sharp dishwasher doesn't work due to H21 alarm
Www.sharphomeappliances.com
visit this site as error codes are usually prefixed with a F, should get the answer from sharp
SOURCE: Alarm Code 10 - Meaning Please?
You can download the manual from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/HB00503_WF840_860_865_19504206802_jan05.pdf
You will need to contact the service helpline for the explanantion of the F10 display
SOURCE: keeps alarmimg 1E on my Lg Dishwasher
Inlet water error 1E
Not reached to the normal
water level in spite
of 10 min. water supply
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound.
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker.
SOURCE: I'm getting an "LE" code also, and the dishwasher will not drain.
LE is a Motor error
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB
SOURCE: dishwasher runs for 5 mins than stops with alarm &...
Refer user manual.
Also check your water inlet for free flow.
SOURCE: Dishwasher showing wrench symbol after using dishwashing liquid
I am assuming this F1 error is coming in only one drawer and that you are able to run the second drawer as normal.
In the case of your dishwasher the F1 error occured because the foam would have overflowed over the drawer top into the base of the unit. This would have triggered a flood switch which is there to protect water damage to the dishwasher. You can either wait a few more days until the base of the dishwasher drawer unit dries up or you can dry it yourself.
To dry the base, extend the drawer as far out as possible (turn mains power off first). The use a few towels and push them on to the base. Pull the towels out and dry the base especially the centre of it with a hair dryer.
The F1 should disappear once you put power back on .
Hope this helps. You have a very helful child who sets the dishwasher up. I have to keep pushing my children to even empty it.
Hi
F2 is a drain error and dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
