SOURCE: sd card not working
for some reason some cellphones don't like the Polaroid sd's. i had to go get a sanDisk micro, it works fine now.
i even formatted the Polaroid and it still did not work.
my nokia likes the Polaroid ...go figure.
SOURCE: get saved music off internal memory onto micro SD card or to lapt
Thanks to the RIAA, you CANNOT do that. The songs are 'stuck' in the radio. The card is for you to add YOUR own MP3s only.
SOURCE: need to save apps to
Unfortunatly due to application Licenses they cannot be saved to SD cards to prevent illegal distrubution of the app as far a permissions to save the apps must be obtained from the creator of the app and 99% of the time they will not release that permission due to the potential financial loss
SOURCE: Why i cn't install apps on my sd card for galaxy
Try installing App 2 SD from Android Market. You should be able to move the installed apps to SD card using this application. Galaxy Mini comes with Froyo and hence you should be able to use this app and move possible apps to SD Card. Moving the app to SD card also depends on whether the developer has enabled the feature to move his app to SD card. App 2 SD will only be able to move the apps which have this feature enabled by developer to SD card.
Hope this helps.
SOURCE: sylvania tablet not reading sd card
all you need is to reprogram the windows and re-configure the drivers for the laptop,
